90+ hp and torque???
I have a 2006 XL883L with a 1200 conversion. I used stock 1200 Jugs and flat top pistons with Screamin' Eagle 10.5:1 compression heads and a Screamin' Eagle performance .575 lift cam. It is pushing 84hp and 78 Torque. How can i get it put out 90+ horse and torque without changing the displacment anymore??????
Screaming Eagle was the wrong way to go. As said you can''t do much with the heads other than polish them. So a bored carb and intake is out of the question. And I'm pretty sure? that those SE pistons can't be used with other heads.
As I said you should asked questions first, especially the one about how much horse power to expect from the build.
You should of asked this question before you built your motor.
x2 what he said
NHRS 1250 kit
Stage 2 light work
SE 487 or 536 cams
Vance Hines sideshots
Tuner and
Screaming Eagle intake
should be good for 100+ whp
You want the simplest solution? Bolt on a NOS injection kit with a small bottle. This way you can pick and choose when you want the extra HP. I used to run NOS on my ironhead just to mess with my riding buddies. They'd quit laughing when I'd roar by, although resume when my advance springs would break.... Doh!
