Rear Fender Removal = Help
Old 01-09-2012, 06:44 PM
Razorback Rob's Avatar
Razorback Rob
Razorback Rob is offline
Default Rear Fender Removal = Help
Once I take all the bolts on the sides off, is there anything else to take loose? Besides the wiring? Thanks in advance.
Old 01-09-2012, 06:50 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
There's a bolt that attaches the fender to the frame under the seat.
Also, don't forget the turn signals.
Old 01-09-2012, 07:28 PM
nc883's Avatar
nc883
nc883 is offline
That bolt he is referring to goes from the bottom up. Once your seat is off you'll see the nut on the top side. Have a buddy hold a wrench on the nut so you can rachet the bolt from the bottom. I was able to remove mine by laying on the left hand side of the rear tire and came up between the tire and the fender. Did not have to lift the bike. The rear turns can be a little tricky if you've never done them before too. The double nutted stud and removing the wires from the deutsch connectors to get the wires through the fender holes, etc.
Old 01-09-2012, 07:31 PM
Ragnar Danneskjöld
I managed to get the fender off myself, too. Some people prefer to drop the wheel or put it on a lift but it's not terribly difficult.
Old 01-09-2012, 08:36 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
Or, with your bike on a lift, unbolt the rear shocks and let the swing arm drop for easy access to that nut.
Old 01-09-2012, 08:52 PM
bmxatv's Avatar
bmxatv
bmxatv is offline
+1......you might have to drop that rear wheel to get it completely off bro.
Old 01-09-2012, 09:05 PM
Razorback Rob
Yeah, yeah. I hear ya I need a service manual. I have a lift I fabbed up. I planned on lifting it and dropping the rear wheel. I just like to have an idea before I go into it. The rear signal are gone. They have been for awhile, so they are not an issue. Thanks guys.
Old 01-09-2012, 09:26 PM
Greatscott's Avatar
Greatscott
Greatscott is offline
You don't need to lift it. It's cake you'll be fine.
Old 01-10-2012, 06:34 AM
bmxatv's Avatar
bmxatv
bmxatv is offline
local laws in my state do not require the use of signals on your bike, assuming arkansas is the same? ever catch any ****? i really want to get rid of mine and use hand signals.
Old 01-10-2012, 07:08 AM
nc883's Avatar
nc883
nc883 is offline
Just remember to note where all of the wiring retainers and grommets and sleeves go, otherwise you'll have a small pile of hardware and no clue where they went.
Quick Reply: Rear Fender Removal = Help
