What are some cheap and easy ways to Increase horsepower?
Don't forget the intakes, exhaust and dyno tune. Thought about the jug swap but realized that I'd be better off doing the heads and cams at the same time. When I am ready, I will have the stuff to do it with since I am exploring tuners and have the intake and exhaust.
What is your budget?
Generally I suggest doing intake and pipes first. They will be beneficial no matter what modification route you go. If you want, you can then go the 1200/1250 route.
For a tune, I'd suggest a PCIII or better kind of solution (PCV, PV SERT, etc). They are better tuning options than XIED/Fuelpak and yet flexible enought to grow if you continue to mod. There are pros and cons to the different solutions so you'd need to decide which would suit you best.
The best advice is get out there and ride your bike as it is for a while. There is no need to race to change it!
Is your goal really to increase power, or is it to make your bike accelerate faster?
The absolute cheapest thing you can do is lighten your bike by removing the unnecessary pounds. The extreme to which you go is up to you entirely here, but every pound counts. Exhaust shields, fenders, reflectors, mirrors, lights, passenger pegs, they add up to decreased acceleration.
In addition to the other options mentioned in this thread previously, you could change your pulleys out - a larger one on the rear or a smaller one on front, or both. This could give you quite a boost on the accel rate, but at a loss of top end speed, and your bike will rev higher at a given speed, but it is a good go fast trick that for some reason not many sporty guys do, but a large percentage of my vrod bros do employ.
