Sputtering at low RPM's
Old 06-13-2012, 09:52 AM
Custom Zach's Avatar
Custom Zach
Custom Zach is offline
Default Sputtering at low RPM's
Specs: 2003 HD Sportster 883C
Hyper-charger with aftermarket pipes. Carb is jetted at #45 & #175 (Carb has been jetted like this for over a year)
I recently did some ignition work to my sporty. I replaced the ignition module, ignition coil and spark plugs.
My sporty is now sputtering while in low RPM's. When I'm sitting in neutral I can rev the engine no problem. Doesn't matter if I'm revving low RPM's or high RPM's it feels smooth. Once I pop it into gear it begins sputtering at low RPM's and I have to keep the RPM's up for it to ride smooth. I've spent hours adjusting the carburetor but I can't find the sweet spot.
Any idea what this could be? It's ride able but kind of annoying at low RPM's.
Thanks. Zach
Old 06-13-2012, 10:31 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
You could just be in too low of a speed for that gear. It's called "lugging".
Old 06-13-2012, 10:53 AM
Custom Zach
I don't think that's it. I know how it feels to be in too low of an RPM for that gear and this is something that feels completely different. When I'm in first gear at a stop and I go to take off it does the sputtering still.
This is what it's like.. I'm at a stop in first gear with the clutch in. I start to take off from a stop and I pull the throttle and it sputters. I haven't even disengaged the clutch completely yet. It's a loss of power and I have to really rev it to get the sputtering to stop.
Old 06-13-2012, 11:02 AM
cHarley's Avatar
cHarley
cHarley is offline
Sounds like the accelerator pump in the carb isn't working or not working well.
Have you replaced the pump diaphragm?
Old 06-13-2012, 11:28 AM
Custom Zach
cHarley - No I haven't replaced the pump diaphragm. I had the carburetor cleaned last week though. If I remember correctly the pump diaphragm is almost at the very bottom of the carburetor right? Would this involve removing the carb or could I do this while it's still on the bike?
Old 06-13-2012, 11:29 AM
Custom Zach
Also.. If that needed replaced, wouldn't it affect me in higher RMP's as well?
Old 06-13-2012, 11:38 AM
cHarley's Avatar
cHarley
cHarley is offline
The pump is part of the float bowl, so you don't need to remove the carb, just drop the bowl.
No, it just provides a shot of fuel when you initially twist the throttle.
You can tell if it's working by removing the A/C and looking into the throat of the carb as you twist the throttle. There's a small metal tube that sticks up into the carb throat that should squirt gas as you twist the throttle.
Old 06-13-2012, 12:17 PM
Custom Zach
OK Thanks cHarley. I'll check that out and report back
Old 06-13-2012, 01:01 PM
Custom Zach
cHarley - it's doing what you said. It seems to be working properly.
Old 06-13-2012, 02:52 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Then you may be lugging the motor (not enough RPMs). Sportsters like it in the 3500 - 4500 rpm range. Especially when your starting from a stop. Try it and see. Then we can take it from there.
Quick Reply: Sputtering at low RPM's
