rk air shocks for a 1200l
greetings to all.
rk shocks arrived yesterday. just bought the airguage/pump for same at dealer...but they were out of the valve/valve assemblies needed to complete the install.
stopped at napa... got two 1/8 mnpt industrial tank valves29/32" length. removed plug that came with shocks with a 7/16 wrench. valve assembly threaded right in.
so if i install both shocks today, i imagine i'd have to add air pressure individually to each shock. am i correct or am i missing something? do i need to get the schrader valve assembly /hose/ valve assembly kit from harley? i want to ride TODAY.
thanks in advance...semper fi.
Do you happen to have the part number on those valves?? I'm thinking of using individual valves instead of the combined valve with the lines...
And yeah... plenty of people riding like that. Just check for leaks, I pumped mine up to about 20 psi and let it sit for a while, took a quick ride and used the pump to recheck the pressure... no loss. Its easiest to pump 'em up to about 10psi, then use the button to lower the psi down to where you want it. I run at about 5.
Yeah, you would just have to fill each shock individually, but the pump makes it easy to fill to an exact PSI.
Received 3,941 Likes
Been running mine for years with a valve on each shock. I check the PSI periodically. Kept em both at 5 PSI each until I installed lowering blocks, now keep about 10 PSI in each.
Let us know how you like the ride!
greetings to all.
replies to all
length of rk's i got was 12" did NOT lower bike(original shocks are 11.5").
napa part number for valves...hold on. going through trash...ok; "industrial tank valve" 1/8 mnpt. 29/32" length. part # 90-290.
i also ran the psi up around 10, and bled down to about 5. going to ride in a half hour after i cut the lawn.
