Hi I want to paint my sprocket cover black on my nightster. Do I have to remove the exhaust pipe to take the cover off?? Just checking with you guys first to see. I hope it's just the 6 screws and done? Let me know.
Thanks guys!! HD newbie here
Remove the cover you will need to unbolt the right side rear shock to do it. Should go back on simple enough with the left side shock still on.
Maybe I'm just confused, but why would he have to unbolt the shock to remove the sprocket cover? I took mine off without removing/unscrewing anything else.
you could go buy the correct allen wrench or allen bit and a 1/4 inch combo wrench. im on mobile so i cant see what pipes you have. i took my cover off without removing pipe.
