New HD Sportster Owner with a question
I just purchased a brand new Sportster 1200 Custom on Monday and had a question about the exhaust. It has about 20 miles on it now and here are my questions. Thanks in advance for the help and I look forward to visiting this board often.
1. Is it too early to change out the exhaust or add slip-ons? Do I have to wait until the breakin period is up?
2. I've been browsing around for recommendations and it looks like slip-ons are the way to go. Will this require an ECM update if I only change the slip-ons?
I found these on eBay which looks like what a lot of folks are talking about.
http://cgi.ebay.com/ebaymotors/VANCE...mZ230091617271
Brian
Brian
RE: New HD Sportster Owner with a question
Welcome aboard, and congrats on the scoot.
If you only add pipes, I'm pretty certain you don't have to update the ECM. I know I didn't have to rejet the carb on my bike, just for adding pipes. I didn't have to do the rejet until I installed the Screamin Eagle Air Cleaner.
I wouldn't think the amout of miles would matter. I've heard of people getting the screamin eagle slip on mufflers installed before they took delivery of their bike.
I'd suggest that you ride it for awhile to get a feel for the set up as a whole. Once you have familarized yourself with the existing set up, you can then begin to make your own kinds of changes. I would bet that those that bought their bikes with changes made before delivery were probably former owners of a sportster or, had ridden one for awhile. The exhaust changes will not require an ECM change. You'e just letting the pressurized hot air out faster. Slip ons are a good alternative to a full exhaust pipe change. Not the same, however. If you feel the need, then you can do it at any time. Just my 2 cents. Have fun. Ride safe.
You can change the mufflers anytime. Had SE mufflers added by the dealer when I bought the bike.
The exhaust your looking at (Straightshot slip-ons) sound great on my Lowrider (Quiet Baffles).
Should sound great on your Sportster.
Go for it!!!
Sammi
Go for it!!!
Sammi
I had the slip on's SEII installled with 300 miles on the OD, then the SE A/C at 700 with the re-map.
It would be nice to wait till its got 1000 miles on it then when you do the up grade and twist that throttle wide open after the upgrade you will be able to fell the difference.
I can't tell much difference after the upgrade because I never really leaned on it that hard before the upgrade, but it does feel strong thru all the gears.
I had the H/D do all the work, bought the parts at the dealer also.
Tom
Tom
If you have to re-map with after maket slip on's you would be wasteing money not to do the stage 1 upgrade, with the a/c. I would supose you would have to check the re-map after a A/C was installed. Another 1/2 hr labor and $150.
I like the H/D slip on's, some say there not loud enough thats a person preference.
If you don't do the re-map as the dealer suggest with after market pipes I guess there is a chance you could damage the engine. Can't make that decission for you!
Tom
Tom
