Thought on mixing oil in primary/engine?
I use Mobil 1 V-twin 20w50 in the engine and Formula+ in the primary. I've been contemplating switching to Mobil 1 gear oil in the primary. You'll get a lot of opinions here, but generally, as long as you don't have two different oils in the same hole, you're fine. And even then, it's usually not a problem. Most oils are compatible, I believe, it's just that the additives aren't always good together.
Received 3,941 Likes
That is what I have done for years...primary does not know what is in the engine, and vice-versa. No problem.
There is no reason you can't do as you ask about, although personally I wouldn't use synthetic oils old chap, it just adds unnecessary expense. I do in my S&S big twin, as it is recommended. For a wide range of options take a look at Opie Oils (for UK members!). I plan on using Silkolene V-Twin synthetic, not least because its British!
I actually mixed oils in the engine this year:
I had HD dino 20w50 in the engine but during the hottest summer months (Southern California) I drained out 1 quart of the 20w50 and topped up with 1 quart of straight grade 70 dino.
Then come winter, I plan to replace all 3 quarts with 20w50 again.
Is that a bad thing to do?
