03 sportster wont start rebuilt carb has spark has good gas
I ride an 03 sportster 1200xl custom. Two weeks ago it was running perfect, i parked it after a ride and it never started properly again. I assumed bad gas, dumped it cleaned the strainer replaced the gas. Traced the gas all the way to the bowl in the carb. Have spark on the plugs and a fully charged battery. Previously changed the plugs, plug wires and ignition COIL. When that didn't work I rebuilt the carb. Still has the same symptoms as when it originally wouldn't start. I turn the engine over and it does several different things. It will either spit out the carb, backfire like a shotgun out the exhaust, or smoke out the carb. The part that is confusing me is every once and awhile it will start from either messing with the air/fuel mixture screw or the idle screw. When it does start it runs better than it ever has (im assuming the carb had been due for a rebuild for awhile) it pulls strong sounds great idles perfect it runs completely flawlessly. Then I go to start the bike again and it wont start again. It NEVER starts twice in a row whether its still warming up or fully warmed up. I cant imagine the fuel/air mixture has anything to do with it because when it does start it runs amazing.
I will look into how to check the VOES. I have not replaced vacuum lines but did inspect them and found no issues. I cant use my plugs as a reference the bike only starts 1 out of every 100 trys so the plugs become fouled pretty quickly I'm on my third set of plugs trying to solve this problem.
I'm getting ready to work on a 2002 1200 Sporty. I would check the float level and the make sure the needle and float move freely. Sounds like like your flooding.
Just because your original problem stated as one thing (like dirt) then after the rebuild dirt or other mysterious force misadjusted the float. Its very easy to do.
