Can you ID this exhaust set up?
Hello folks
Just picked up my first cruiser. 08 nightster. Can you identify what brand is the exhaust set up from the pic?
Also is there a way to check if the bike has been tuned/remapped?
How much does it cost to get a custom tune at dealer/Indy shop or perhaps buying a power commander? Which gives the best performance for the buck?
Thank you.
Thank you.
I should add that the mufflers are definitely not stock because they are loud as hell and the guy did gave me the baffles fiber glass inserts for them. I will be putting em back in, I should also gain better performance by doing that right?
Thanks for your input, i would like to get a confirmation on the brand of this exhaust.
^thanks I'm super excited about getting this bike, however I'm having issues with charging system so can't ride it until it gets solved.
On the exhaust note, I took the heat shield off and didn't see any stamps on the neck or anywhere on the muffler.
Took some pics let me know if this helps in confirming the mufflers? Note the silencer baffles that came with the exhaust if that helps.
Thanks.
Thanks.
