Stiff throttle/sticking
1998 883
So tonight I noticed my throttle was really stiff and sticking.
I checked the throttle lock. Whether it's all the way out or all the way in it makes no difference. The cables look like there's no binding. I checked at the carb that both cables move. So the return hasn't come out.
I'm going to try to lube them tomorrow with wd-40. It's the only lube I have readily available
Any other ideas I should try
Received 2,189 Likes
WD40 is not what I would recommend, a much better choice is Dri-Slide, which can be found at most places that sell firearms (Sporting Goods stores, gun shops, etc).
Dri-Slide goes on wet an dries to a graphite like powder. It won't attract dirt like oil will, which is what gunk's up cables to begin with.
I did notice today when I went out to check on it. Haven't done anything and the throttle works fine now.
Last night it was a little cold. Is there something that the cold would cause to get stiff
you and your big brain. it make sense wy i suddenly had that issue when i was recently in NC. i fiddled with adjuster repeatedly
Update:
Completely lubed both cables with the proper tool and proper lube. Used a whole can between the two cables. Also took out the carb and cleaned the butterfly valve. Also lubed between the bars and the grip
The dang thing still sticks really bad when it's cold. Last night it dropped to 60 degrees and my throttle was really stiff.
The only thing I can think of next is replacing the cables.
Your bike did not get knocked over on the throttle side? The grip is not sticking to the bar end? That happened to me.
John
