Hot and Muggy.. 883 running like shit
Hot and Muggy.. 883 running like ****
Is this just a coincidence? bad tank of gas?
been running 'off' for 2 days now.. i had filled up at a diff station that normal and it ran like **** for a day so i ran it empty and filled up where i normally go and though better, a bit off still - around the same time its been 30+ degrees and humid, could this be why?
Received 3,940 Likes
Engines like cool dry air going into the intake...so ambient temps and humidity will make some difference, but it should not be extremely radical.
If the engine is getting too hot, that will make it run like a dog.
A bad tank of gas can make a big difference also. Even though you ran it dry, if you're carbed it may have gummed some things up a bit.
