Derby, Chain Inspection, and Timer Cover torque specs ???
Before anyone gets on me YES I KNOW I値l be getting the service manual soon.
14' Iron 883
Hey guys I wanted to see if you could help me out. I値l be swapping out my
キ DERBY COVER
キ CHAIN INSPECTION COVER
キ TIMER COVER
and wanted to know if you guys knew the torque and bolt sizes and if Loctite is needed for these covers.
The only two I keep finding specs for is the Derby Cover in which I keep seeing Torque: 84-108 in/lbs. Bolt: Torx T27 and the Chain Inspection Cover, Torque: 40-60 in/lbs. Bolt: ???
Well any help you guys could give would be great thanks.
14' Iron 883
キ DERBY COVER
キ TIMER COVER
I would only tighten them gently hand tight (one hand on head of 1/4" drive ratchet) and no Loctite. Most people swap out the T27 for buttonhead or caphead allen screws. Please leave the torque wrench in the toolbox. Not sure about the timer cover, mines done with poprivets.
Torque Wrench ***** have broken more than they've fixed IMO. Especially on tiny screws like these. You don't need one for everything, only the big stuff.
John
John
John I miss your posts and since of humor.I try to troll back here at times. Come jump the fence and visit Dyna side.I double dog dare ya. Use anti seize on derby, tighten criss-cross star pattern. Use blue on inspection cover and follow spec as too tight will leak. Timer has nothing behind it so really doesn't matter. Don't rely on what may be fastener head size. Verify and common sense will let you know. If you didn't use right size you didn't use your common sense.
I get what you池e saying about the torque ***** and I usually do things by hand tightening but being that this is my first HD I guess I figured I wanted to do things by the book.
I have a in/lbs. torque wrench that I could use for these settings and if I知 right I think its 12in/lbs. per 1ft/lbs.
Saw that on Google.
Saw that on Google.
Saw that on Google.
Saw that on Google.
As for being a ****, with six bikes in my garage, I torque when I can because it's an objective method to ensure it's the right amount of stretch for the screws/bolts. My wrenching isn't that finely calibrated. Too much and they'll break and not enough they'll vibrate out. I've seen exhausts come loose on the MX track because they were tightened by "feel." The bolts were either completely missing or heads were sheared off. One in particular resulted in a full system destroyed which sucked because it was a Yosh slip-on with a stock header.
Inspection covers, probably not a big deal but IMO anything that's a Jesus nut is a bigger deal. I agree with John on the big stuff but add that anything that goes into the case is a big deal too. If you shear off a head, that can be a real pain in the ***.
14' Iron 883
キ DERBY COVER
キ TIMER COVER
14' Iron 883
キ DERBY COVER
キ TIMER COVER
Received 2,189 Likes
straight from the harley site.
all here:
https://www.harley-davidson.com/en_U...ER/file-7.comp
register your bike and you'll find all this stuff there.
here: http://www.harley-davidson.com/conte...me/owners.html
>> sign-in / create profile (upper- right hand corner)
