Clutch not disengaging completely??
1,900 miles on my new '14 Superlow 883. When the engine is OFF and in gear, when I pull in the clutch, it feels like it's still in gear when I attempt to push it.
When the engine is running and I pull in the clutch and shift into gear, I can feel a slight pull as if the clutch isn't disengaged entirely.
Is this normal or does the clutch need an adjustment?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
This is NOT how you adjust your clutch, this is how you adjust your clutch cable tension. The clutch adjustment is under your derby cover which you need to remove first. I would suggest a factory service manual. Clutch cable tension can be checked simply by grabbing the end of your clutch cable housing where it attatches to your clutch lever, pull the housing away from the lever it should pull outward no more than 1/16 to 1/8 of an inch. If it moves more than that it requires a cable tension adjustment. This will not adjust your clutch however.
Received 17,598 Likes
benjamin lorenzo (10-30-2021)
