I want to see your mustang tank
I'm trying to find as many pictures as I can of Sportsters with mustang tanks, but all of my search results for "mustang tank" return threads about Mustang seats and tank clearance
Anyway, if you have a Sportster with a mustang tank, I want to see it! And maybe know where you got it and how large it is................
Thanks!
Thanks!
Here is a really stupid newbie and off topic question (and it will bump your thread a little):
When you have two gas caps on your tank, does it means you have two completely separated/independent tanks on the bike or is it just for looks? If it's two tanks, do you have two fuel valves with reserve etc.??
I am about to put a mustang tank on my 2002. I think one of the reasons you aren't seeing many answers is because the mustang tank doesn't actually fit on a sportster. I am having to modify it. First thing i am doing is moving the petcock to the rear right so i don't lose a gallon of gas mileage. Second i am welding extensions on the front which will frisco the tank a bit and connect up to the holes on the frame. Then i need to weld two more brackets underneath the tank about 3/4 of the way back to line up with the second set of holes on the frame. This will give the tank the appearance that it is floating. I will post pictures when i am done.
I really like the gap between the seat and the tank that the 2.1 peanut provides, and this 3.2 mustang is the same length/height, but a tad wider
