Well I did it too
Well just to let everyone know I now have about 1500 miles on the CT and air pressure down to 34#. It rides good, Momma likes it, but it will grab the road grooves, Damn Oil Field trucks.
Only problem I am having is a wobble at 85-90 mph. If I can get that solves it be golden
Best example-BF Goodrich AT 90% of those tires require anywhere between 3-6 ounces of weights on each side of the wheel on a superduty. I would road force them mark the sidewall and rim release the air break the beads down lube up the beads and rim slide the tire until the marks lined up, re balance. If it still needed substantial weight to balance out or there was excessive road force and the customer wanted the truck back same day, I'd put those on the rear and the lighter weight on the fronts. I'd also split the weights as a 3 ounce weight is less appealing than 2 1.5s spaced 3 inches apart. If they didn't mind waiting, I'd get another tire shipped for excessive road force.
Dot tags also area good thing to pay attention to, as you will get the production date (last 4 digits week # and year) most problematic tires usually sat on a shelf for 3+ months
And as a suggestion, if I were to go that route, given the nature of wider tires yielding less traction (drive a dually in the snow or a car/truck with wide tires in the rain or snow) I'd suggest getting a tire that had an aggressive water evacuation tread pattern such as a Kumho ecsta (they were popular for ford focus/fiesta/fusions) it never failed to take the bike out and get caught up in a rain storm. You may not like the ride of run flats as the sidewalls are SUPER STIFF.
