The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
No Device: Dyno Correction factors and smoothing
Old 04-25-2016, 05:15 PM
Wide Open Cycles's Avatar
Wide Open Cycles
Wide Open Cycles is offline
Former Sponsor
Default Dyno Correction factors and smoothing
In an effort to get this part of the forum I figured i'd start a thread about correction factors and smoothing, and how they affect the end results on our dyno sheets.
There are many different correction factors, i'll go over the 3 main ones that we see. A modern dyno basically has a weather station built into it, it gives is real time temperature, humidity, barometric pressure and so on. Correction factors were developed to be used as a tool to compare results on different regions of the world. i.e. the results of an engine dyno'd in California could be compared to an engine dyno'd in Detroit, or anywhere else.
I took a bike I tuned recently and decided to use it as an example. I'll post the sheets in the differn't correction factors.
SAE correction: SAE corrects the actual run conditions to a standard of 77°F (25°C) with 0% humidity and a barometric pressure of 29.234 in-Hg (99 KPa).
STD correction: STD corrects to 60F (15.5C)with 0% humidity and a barometric pressure of 29.92 InHg (103.3 kPa)
UNCORRECTED: Uncorrected is exactly what it says, it is what your engine produced at the time it was ran on the dyno. that temp, humidity and barometric pressure.
These are all the same exact run, just with the correction factor changed. If you want to have an accurate comparison you need to make sure that the correction factor is the same. You can see in the example above that this particular bike made 3.71 more HP and 3.83 more torque simply by changing correction factors!! You can see that it made even more power and torque UNCORRECTED, it was an exceptional day when I tuned it. Hopefully this clears up a little on the correction factors and more importantly, how shops can use them to show better results.
The following 2 users liked this post by Wide Open Cycles:
Gordon61 (04-26-2016), Mr. Wizard (04-25-2016)
Old 04-25-2016, 05:36 PM
Wide Open Cycles
Former Sponsor
Let's take this one step further and talk about SMOOTHING. Smoothing is basically exactly as it seams, when you run a bike on a dyno the lines are naturally "choppy", smoothing averages out the peaks and valleys. A smoothing of 0 (zero) has higher "peaks" and lower "valley's" than higher smoothing.
Let's now look at the same charts from above and change the smoothing factor to 0 (zero) and see what happens.
Keep in mind, these are the same exact runs as above, just with smoothing set to 0 (zero).
SAE CF Smoothing 0
STC CF smoothing 0
UNCORRECTED smoothing 0
So by doing nothing but clicking a couple buttons I can take this sheet and go from the lowest (SAE CF smoothing 5) and convert it to the highest (UNCORRECTED smoothing 0) and gain 5.69 HP and 5.82 TRQ
So in conclusion, when comparing dyno sheets make sure you are comparing apples to apples. I'm Leary of shops (in the US) that give printouts in anything other than SAE smoothing 5.
The following 3 users liked this post by Wide Open Cycles:
FLTRI17 (10-06-2018), Gordon61 (04-26-2016), Mr. Wizard (04-25-2016)
Old 04-26-2016, 03:21 AM
msocko3's Avatar
msocko3
msocko3 is offline
Great information, thanks for posting this up.
Old 04-26-2016, 05:02 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
great info,
when a dyno sheet is printed to SAE should it only have the SAE standard run conditions listed on it or are they the run conditions of the day?
Old 04-26-2016, 06:27 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
If you have the time. Post up sheets showing conditions and corrections factors for SAE and STD.
Old 04-26-2016, 07:00 PM
Wide Open Cycles
Former Sponsor
Originally Posted by mirrmu
great info,
Those are the run conditions for the day it was run.
mirrmu (04-27-2016)
Old 04-26-2016, 07:02 PM
Wide Open Cycles
Former Sponsor
I thought of that right as I was posting them, but I saved it to a thumb drive and posted it from home. I'll try to remember der to do it tomorrow when I get to the shop. Thanks Jason
Old 04-27-2016, 01:42 PM
Wide Open Cycles
Former Sponsor
Here's the same runs with the Conditions
msocko3 (04-28-2016), rigidthumper (04-27-2016)
Old 06-27-2016, 12:20 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,255 Likes on 3,627 Posts
If you take the run file home instead of the Dynojet printouts and download winpep7 on your home PC, you can create whatever view you want at home instead of having to do it at the shop.
JimmyDee
12-24-2012 08:49 AM
scotty-j
Great Lakes
04-25-2009 10:48 AM
silvrbill
Exhaust System Topics
06-25-2008 01:00 AM
FACTION95
22
02-18-2007 12:23 PM
Baggerdad
12-10-2006 09:27 PM
Quick Reply: No Device: Dyno Correction factors and smoothing
