Wild 1's 578 or LA Choppers twin peaks 10"
Heated grips quit working after installing new bars
I am a newby to this site so forgive me if this post should be somewhere else..
I recently install new 10 inch bars from LA Choppers on my 2014 limited. Everything works but the heated grips. Anyone have any suggestion? Thanks in advance for any help.
I have the 578's and my only complaint is that after grips and levers are on the bars are wider than the fairing. It hasn't been a problem with wind but I'm in Ca. where splitting traffic is legal and necessary.
also the poster is correct that you'll need wire extensions as well as +4" clutch. I didn't have to change brake line but it was just long enough. I couldn't find the exact bar I wanted and the 578 came close. Hand/wrist position is comfortable. Good Luck.
The connector pin tool makes it so easy. I tried using a paperclip before I ordered the pin tool and it sold me on getting the right tool for the right job. I had an old switch housing and I tried it on that. I got some of the pins out, but some of then were stubborn. I got the pin tool and its WAY easier. Pull the scendory lock, put the tool in the hole, push and pull the wire out. Only gets to be a pain in the *** when the wire turns and gets stuck inside the housing and you have to pull the back off to get it out. This is the one I have. Works great. http://www.ebay.com/itm/Harley-GENER...38ce42&vxp=mtr
Narrowed down my choice on new bars to these two,,, I think. Going on a 13 SG and want my hands out of the wind, so 10" is as high as I will go. Like the looks of the Twin Peaks and that they are 2.5 inches narrower than the 578. With the 578 being wider, in some pics it looks like the ends are out past the fairing. Maybe an illusion from camera angle. Have not had the opportunity to sit on a bike with either installed or even seen bikes in person with them installed so looking for pros and cons from owners on these bars. Don't have much time to decide since the my bike is in getting repaired from a deer hit and they need to know fairly soon.
