Red Line 20W60HD
Old 04-12-2007, 10:55 PM
JeffSG's Avatar
JeffSG
JeffSG is offline
Default Red Line 20W60HD
Anyone use this oil? My tuner tells me that it will make my engine run about 20 degrees cooler. Good for warm climates only. Ordered some today online, and could not find anyone local that carries it.
Product website:
http://www.redlineoil.com/products_m...;categoryID=11
Peace,
Old 04-12-2007, 11:07 PM
bay13's Avatar
bay13
bay13 is offline
Default RE: Red Line 20W60HD
I'm running it in my bike right now. You said it makes your bike run warmer?
Old 04-12-2007, 11:37 PM
berettag's Avatar
berettag
berettag is offline
Did you mean to say cooler?
Old 04-12-2007, 11:56 PM
Ram's Avatar
Ram
Ram is offline
Clermont, FL. is pretty much a warm climate, and RedLine is a friction reducing ester based product with excellant thermal stability, which you need in a warm climate!
I'd say that its a: "20* cooler running oil that isuseful in a warm climate."
I say go for it, I did. Great Oil.
Use RedLine in all three holes.
Old 04-13-2007, 12:06 AM
fxdwg_rugby's Avatar
fxdwg_rugby
fxdwg_rugby is offline
I have been running Red Line shock proof HD oil in my trannies and love it...
Old 04-13-2007, 12:12 AM
Gaskett's Avatar
Gaskett
Gaskett is offline
Using it it mine (Melbourne FL). Also use the Shock Proof Heavy in the transmission. THe tranny fluid made the bike shift smoother, reducing the "clunk" when it goes into gear.
Glenn
Old 04-13-2007, 12:55 AM
Indianspringsaz's Avatar
Indianspringsaz
Indianspringsaz is offline
I hope you ment cooler[8D]
Old 04-13-2007, 01:10 AM
fatboylust's Avatar
fatboylust
fatboylust is offline
I use the Redline 20w-60 and the thing about multi-grade motor oils is:
"At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20w-50 as a 20 weight oil that will not thin more than a 50 weight would when hot."
So the idea that one 20w-60 is only suited to warm weather is misguided as it will always be 20w oil when cold just like 20w-50 or 20w-40, butat the upper end thepolymers in the 20w-60 will hang in there longer than the 20w-50 etc.
FBL
Old 04-13-2007, 01:56 AM
twsteddyna's Avatar
twsteddyna
twsteddyna is offline
Titan Motorsports in Orlando carries this oil http://www.titanmotorsports.com/redline.html
Old 04-13-2007, 05:49 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: fatboylust
FBL
So 60 weight would be when its hot. THat means it is in fact a hot'er weather oil. If it was a colder weather the low number would drop to 10 or 5 wt.
Quick Reply: Red Line 20W60HD
