2014 Street Glide Special Monkey Bars Install
Greetings fellow Riders,
Fairly new to HD Forums and have already solved numerous issues thanks to all of you! Onto my next project...changing out the stock bars for Paul Yaffe 12" Monkey Bars. So let me start the debate, do I need to change out the clutch and brake lines? Do I need the 4 and 5 wire extensions for left and right side? Do I need TBW extension?
Some post indicate just the 4 and 5 wire harnesses need a small extension. Many of the aftermarket wire extension companies (LA Choppers, NAMZ, Burley, Guerilla) all indicate that ONLY the 4 and 5 wire extensions are needed and TBW is adequate. Further, I could not find any info on whether the stock hydraulic clutch and upper brake line needs to be replaced, and if so to what length beyond stock (i.e. +2", +4", etc.)
After reading here that dealing with Yaffe was not the easiest, I found them to be quite pleasant and very helpful on the phone. As advertised by the tech on the phone I dealt with, he said replacing my stock 2014 SGS bars with Yaffe 12" Monkey Bars would NOT require change out of ANY cables or lines! I find this difficult to believe because the stock SGS bars are ~9" and I am going to 12".
I am hoping someone out there has installed a pair of 12" Yaffe (or equivalent) bars on an SGS and can provide some insight. I'd like to have all the parts on hand (if needed) before I start the job. Any info would be greatly appreciated...Thanks!
I installed these exact bars on my '14 Limited.
You need the NAMZ (or equivalent) 8" extensions for the hand controls.
Stock TBW has plenty of length, just make sure you tape and secure the green plug or it will cause problems. Or you can get the SE TBW which does not have that plug. I used the stock with no problems.
The stock clutch and brake lines will work, you just have to clip a couple of zip ties and move them around. Plenty of slack tucked in the fairing.
Part Number
Thanks in advance.
Z
Yaffe Monkey Bar 12 on SG14
I just installed these on my SG14. I did torque the 4 bolts on the clamp at 26 thats what the repair manuel calls for but when I sit on the bike. I pull on the bars down or push up to see if the feel loose they have a little play. Anyone else's monkeys do this maybe they are suppose to have a little play
