se 5.5 oil pan
Old 11-04-2014, 08:24 PM
fmlawn's Avatar
fmlawn
fmlawn is offline
Default se 5.5 oil pan
started on my tman 124 kit 2013 urg. should I go with lg pan or stock, some say not worth the money....
Old 11-04-2014, 08:42 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
That Tman should be a blast!
From all that I have read up on, $ave your money.
Good luck.
YB
Old 11-04-2014, 09:14 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
Does this 124 kit "recommend" a larger oil pan? If not, then don't bother with it. JMO
Old 11-05-2014, 08:29 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
More oil = cooler motor.
Old 11-05-2014, 08:58 AM
Tinman265's Avatar
Tinman265
Tinman265 is offline
And a more stable oil temp.
Old 11-05-2014, 09:10 AM
mmats69's Avatar
mmats69
mmats69 is offline
You don't need it. I will suggest an oil cooler upgrade and wards fans if you plan to do a lot of city riding. I'd call TR just to make sure though.
Old 11-05-2014, 09:15 AM
Rhino-1's Avatar
Rhino-1
Rhino-1 is offline
If the $600 price tag is not an obstacle, go for it. A 124 could probably use the extra cooling. IMHO.
Old 11-05-2014, 10:06 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Good luck.
YB
instead replace your stock oil cooler with a Jagg 10 row fan-assisted oil cooler. that would be money better spent IMO compared to another quart of oil in your system. I haven't seen any technical data that shows that an added quart of oil will cool anything down any better than 4 qts will. There's tons of data on oil coolers though.
Old 11-05-2014, 12:48 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,412 Likes on 881 Posts
I guess, it depends on if the sump does a lot better job at keeping the oil pickup submerged and not cavitating with the high g-load acceleration you will be experiencing.
Old 11-05-2014, 01:34 PM
sporacer's Avatar
sporacer
sporacer is offline
The extra oil wont hurt but Id be more worried about the oil cooler if you don't have one. I am using the stock pan and hd oil cooler on both my 120r and my 124.
Quick Reply: se 5.5 oil pan
