Heat shields?
Old 12-16-2014, 08:41 PM
BuzzL's Avatar
BuzzL
BuzzL is offline
Default Heat shields?
Has anyone removed the plastic heat shields at the seat? If so, any noticeable difference in comfort?
Old 12-16-2014, 10:50 PM
03snake's Avatar
03snake
03snake is offline
Sorry, Edit, you already have the Jackpot SS header.......I should RTFP first!
Attached Thumbnails Heat shields?-dsc_0175.jpg   Heat shields?-dsc_0179.jpg   Heat shields?-dsc_0189.jpg   Heat shields?-dsc02997.jpg   Heat shields?-dsc02999.jpg
Old 12-16-2014, 10:59 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
The heat shields are there for 2 main reasons.
1. To hide the blued pipes.
2. To keep you from a trip to the Emergency Room when you cook your shin or calf from contact with the header pipe instead of just an Owiee from the shield itself.
Old 12-17-2014, 01:45 PM
SWThomas's Avatar
SWThomas
SWThomas is offline
I've thought about it. I think they're there more to channel air into that area for cooling. There's definitely nothing on the right side that would burn me if I removed it. The left side isn't covering anything either, but is right above the head pipe on my MGS true duals.
Old 12-17-2014, 01:48 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
hahaha You should be old enough to look before you leap too !! OP talking about PLASTIC heat shields or mid frame deflectors.
DOH !!
Old 12-17-2014, 01:49 PM
bmaier's Avatar
bmaier
bmaier is offline
OP is talking about the mid frame heat deflectors not the heat shields on the pipes
Old 12-17-2014, 01:53 PM
austinslider's Avatar
austinslider
austinslider is offline
I've been debating about removing them from my RG. Although, I had them added to my old RK, due to the excessive heat from the motor...they seemed to help a bit.
Old 12-17-2014, 02:03 PM
05softailnc's Avatar
05softailnc
05softailnc is offline
Well, the FLHX does not have them, so I put some on. My right leg was cooking in the summer. I can't really say that adding them made a world of difference so taking them off probably won't either.
Old 12-17-2014, 02:06 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
DOH !!
True, but we only know that now because he edited his post today at 12:07 PM.
That is AFTER some of the answers to the way he had worded the original post.
Old 12-17-2014, 02:11 PM
bigheadted's Avatar
bigheadted
Originally Posted by rollamo
true, but we only know that now because he edited his post today at 12:07 pm.
That is after some of the answers to the way he had worded the original post.
doh!!!
Quick Reply: Heat shields?
