Out of curiousity, why do you want to have it in gear while starting? Try it in neutral with the clutch disengaged. Much safer, anyway.It may be a safety switch that is a new thing?
It starts right up in neutral...And I notice the other 2015 Road Glides start while in gear with the clutch level pulled in. You guys may be correct - safety issue. I'll get it checked out...
Mine will start in Gear with clutch pulled in. They found a loose wire on my handlebars while putting the heated grips on. Take it to your dealer and let them deal with it. If your gonna miss any riding make them give you a loaner.
