Question about handlebar wiring
Old 02-21-2015, 11:08 PM
CanuckWhiskey14's Avatar
CanuckWhiskey14
CanuckWhiskey14 is offline
Default Question about handlebar wiring
I installed KST Kustoms 12 inch bars today .. Pulled all the internal wiring .. before mounting the bars back on , I laid them on my covered front fender and plugged in all the Canbus wires and the TBW plug .. thought i would try this before mounting it all up ... Everything worked fine .. Now after mounting the bars and plugging in the connections again ( they were tight ) Namz 8 inch .. the left side controls did not work ... I swear at this time I checked the right side signal it did work but not sure .. Anyways pulled apart again and noticed two of the wired had pulled out of the one left side namz connection ... I have not function on the right side either now ... I am hoping its the extensions but I will have to wait till tommorow and see if our local Harley dealer has extensions ... I hope they do so at least I can see if that is the issue ... Like i said the left side for sure is no good ... Is there a fuse in the fuse box for the hand controls on the 2014 's ?? Any help or ideas appreciated..
CanuckWhiskey14
2014-2023 Touring Models
02-22-2015 08:04 PM
junglejoe
20
11-01-2014 08:57 PM
toybreaker
05-19-2013 10:13 PM
StayPuft
08-10-2012 05:26 PM
FIREHAWK116
08-10-2010 10:34 PM
Quick Reply: Question about handlebar wiring
