Wiring Issues
Old Aug 5, 2012 | 12:04 AM
StayPuft's Avatar
StayPuft
1st Gear
Default Wiring Issues
I've got a 2003 XL883C and I just installed drag bars, and new grips and levers, at some point during disassemble or reassembly I think I may have damaged the wiring to my controls. After install I blew the fuse for my ignition system, I replaced the fuse hoping that it was a one time thing. Next start-up went fine, and then the third my headlight went out... I have little/no experience working on my own bike and hoped this install would go smooth but now I'm stuck. If anyone can give me some tips or finding the short, or even advice on redoing my entire wiring I would greatly appreciate any help.
Old Aug 5, 2012 | 09:14 AM
run1fsr's Avatar
run1fsr
Sounds like you have something shorted to ground. Did you disassemble the switches or cut the control wiring to route through your bars?
Old Aug 5, 2012 | 10:12 AM
Gpsjr10's Avatar
Gpsjr10
First question is: Are your new bars dimpled or drilled to allow the wiring to pass through the clamp and into the switch housing without being pinched?
Old Aug 5, 2012 | 03:21 PM
StayPuft's Avatar
StayPuft
1st Gear
The bars are dimpled to allow the wiring from the controls space so didn't have to cut any of the wiring, I replaced the second blown fuse but am worried this is going to lead to further/more serious issues.
Old Aug 5, 2012 | 05:22 PM
run1fsr's Avatar
run1fsr
So the bike starts and runs fine with a blown headlight fuse? Sounds like that's the problem circuit.
Old Aug 5, 2012 | 10:12 PM
Gpsjr10's Avatar
Gpsjr10
Somewhere a wire is probably pinched. If the headlight circuit is giving you trouble, open up the left switch housing and see if something is shorted to ground.
Old Aug 10, 2012 | 05:26 PM
StayPuft's Avatar
StayPuft
1st Gear
Thanks for the help I took off both controls and wrapped each wire individually where there was a "splice?" and have been good since then. I think it was shorted to ground as you guys stated. Thanks again for the tips!!!
purpledeuce
Milwaukee Eight (M8)
Jul 10, 2017 11:15 AM
Mr.Twisted
Sep 6, 2013 04:21 PM
08Spikester
Jun 22, 2010 07:42 PM
anubisss
Jul 20, 2009 02:03 PM
Hoffy
Mar 29, 2009 11:02 PM
