Question On Internal Wiring With a Bar Swap
Patience is your friend my friend. I use a fairly thick weed-eater string to pull my wires through (the thick black craftsman weedeater string). I've done it several times and it works well. I've installed several Vindikta SG bars that have the upper sharp point. For me the weed-eater string gives it a nice round bend over the edges. I also found that it was as much about pushing the wire through as it was about pulling the wire through. I was able to push the wire through and pretty much only pulled it enough to give it the direction to go.
Good luck!
Good luck!
A little update, I got some 5/8" vinyl tubing and pulled it through the bars then ran the wiring through that. The soft tubing went in like butter and so did the wiring. This was not only easy, but it will protect the wires from getting nicked on the edges. Just finished one side, now headed to the next side. Thanks for all the other ideas
The tubing is just basic 5/8" sold at Home Depot. But, as my luck always runs out, the tubing on the other side got stuck somewhere in the middle and my wire pulling it in broke, leaving the end of the tubing in one of the bends somewhere. I cant even pull it out or pull a new pull-wire through it. I think this is my last road block on these PITA bars
georgiabiker
03-19-2008 06:57 PM
