2 Dumb Transmission Fluid Questions
I'm no mechanic, so these questions may be the dumbest you've ever read. (Bike is a 2011 RKC)
1. When checking the transmission fluid, should the bike be warm or cold? The service manual seems to suggest cold, but it doesn't come right out and say it. (It just says to let it rest for a short period of time if it's just been ridden to allow the fluid to equalize.) Other sources say to warm the bike up and shift through the gears before checking, but they also say to check the fluid with the bike upright and the manual clearly says to do it on the jiffy stand. Which is it--warm or cold?
2. When I checked it cold, the fluid is at the bottom of, or just below, the marked range of acceptable levels on the dipstick. If I want to bring it up to the middle of the range, how much fluid should I add to move it from the bottom of the range to the middle of the range? (I don't want to overfill.)
I think letting it rest after riding or cold would be the same thing as long as you give it time to drain back if you have just ridden it. As far as how much to add, I would just add an ounce at a time until you reach the desired level and make sure when you are checking it that you don't screw in the dip stick. This is from the owners manual if you didn't know.
When checking the transmission lubricant level, the motorcycle should be leaning on the jiffy stand. If the motorcycle was recently moved or ridden, allow a short period of time to equalize lubricant level in the transmission compartments
The procedure could be different for purple bikes, not sure. LOL, Just kiddin Kurt
Location: Western Illinois, land of bad roads, and corrupt politicians
Here's the quote from the 2011 touring manual:
When checking the transmission lubricant level, the motorcycle should be leaning on the jiffy stand. If the motorcycle was recently moved or ridden, allow a short period of time to equalize lubricant level in the transmission compartments.
Since the transmission doesn't get scalding hot like the engine, I don't think the level is going to change that much from cold to hot. And also, the manual suggests checking it as part of your pre-ride ritual. That infers cold.
Sorry, right after I posted this I went back in and edited that my manuals were for a 2015.
I think the OP should check it cold, take it for a ride and see if it makes a difference. Too cold and windy here to try it.
When the bike was serviced. The trans fluid was changed so as long as the correct ampunt was put back, and the bike is not leaking from anywhere, why would you need to add or even check. I maintain my bike and if there's a leak I fix it. So as long as there is no leak then as far as I'm concerned there's no need to check till next service. Is your bike leaking?
Not to mention the lean angle differences when over on the jiffy stand, which results in different levels for the dipstick. For the love of a straight down dipstick that you read with the bike upright.
