Change the PIN code on a 2015 Harley Touring:
Happy Friday All,
I wanted to pass along some information that I needed to learn myself.
I hope this is helpful to a lot of you out there.
Start with the Ignition in the Off position and the Run/Stop switch in the Off position.
Turn the Ignition switch to the On position.
Turn the Run/Stop switch On-Off-On-Off-On.
Press the Left turn switch 3 times quickly, followed by the Left turn switch 1 time.
The Odometer should display the current PIN code and the first number will be Blinking.
Use the Right switch button to change the number. It will count up from 0 to 9.
Use the Left switch button to "Enter" the number and move the cursor to the next digit.
When finished inputting the new PIN code, turn the Ignition switch and the Run/Stop to Off.
The new PIN code will be Saved.
Yep, the one some don't ever open.
It might take a few tries to get the hang of it, but the book is correct.
Yep
