King tour pak refurbishment questions
I currently have a cheap Mutazu tour pak on my FLHP because I wasn't sure how much I would use it. Of course I never take it off. Realizing that it was a cheap, short term solution I kept an eye out for a better quality tour pak. The search paid off as I picked up a king tour pak on CL for $100. It needs a paint buffing, new weatherstriping, and a lock assembly. It came with a lock cylinder, but no key or hook assembly. I tried searching the net and ebay, but am unsure exactly which lock assembly I have or need. Also, does anyone know of a locally available weatherstiping that I can pick up at the auto parts as the stuff that was on the pak was rotted and unidentifiable. Any guidance is appreciated.
I take a piece that is on the old part and take it to a window car shop. The either have it or can order it from a catalog.
Doesn't get any simpler.
Some auto stores carry some.
I would take what part of the lock asemblely to the dealer and compare what will work.
If you can I suggest considering a CVO lid holder. It has a spool to keep the access out of the way. Very helpfully I may add.
Hope this helps
Hope this helps
Dan,
Some photos of the weatherstriping would be great. I didn't realize that it was such an old tour pak. In searching the internet it appears that HD no longer stocks that lock assembly. And the cheapest replacement I have found is over a hundred bucks on ebay. My good deal might not be such a good deal afterall. I guess I will research if there is a direct replacement for this style pak. If not, I may just cut my losses and keep looking for a tour pak.
He sells the latch kits. I contacted him via eBay and asked just for the rekey kit alone and he was happy to oblige. Super nice to deal with!
No problem. His eBay store is at http://stores.ebay.com/tombuyandsell?_rdc=1
