Rear Axle Nut Adjuster Adaptor
I've never had a problem with snail type adjusters moving once there was a bit of tension on them. If I did I'd just add a wrench to the welded side to hold it in place.
Also, I've never used a torque wrench on a rear axle either. I simply snug it up tight enough than I'm confident it won't back off - and they never have.
OP: don't over-think this. You're just tightening the rear axle, not torquing down some heads or rod bolts. If the adjuster slips a tiny bit your belt isn't going to snap in half because you didn't use the correct tool.
I have couple of these, if you notice it has a square hole in the handle for the torque wrench.. works for me http://www.ebay.com/itm/Motorcycle-R...62c0d9&vxp=mtr
I have this one & it works perfectly. It accepts a 3/8" torque wrench.
Over tightening usually isn't an issue as long as you aren't using a cheater to tighten things up.
The spacers do not load the bearings - they only clamp all the spacers and inner bearing races together.
