kuryakyn extended brake pedal pad
Has anyone used the extended brake pad for touring models? I believe you use you existing pad in the insert of new pedal pad, extending it out about an inch. I see it comes with 2 holes but there is only one hole on hd pedal. Do you have to drill a second hole ? Am going to order it but was curious. Stock brake pedal doesn't extend out enough with air filter
Thanks
Thanks
BigDaddyMike
01-20-2009 07:42 PM
