Humming Sound on Left Hand Sweepers
Looking for some suggestions as to what would cause a humming sound (coming from what sounds like the front wheel) when taking a left hand sweeper traveling at speeds above 30 MPH. Almost sounds like a wheel bearing but I would think at only 6K miles on a new bike this would not be the case.
Could in be possible the tread pattern of the tire, but I only hear it when going left.
Suggestions would be appreciated
Tire cupping and or bad wheel bearing would be most likely cause.
BTW,many things can go bad at low miles,compsensator was completely shot on my 09 at only 9,700 miles .
If it turns out to be a tire cupping issue remove the wheel wts and install proper max amount of of ride-on rec for your front tire size into the front tire which will properly balance it.
But the reason i rec here is mostloy because even thought its not mentioned by mfg installing ride on in a bike tire that noisy/humming/moaning when cornering because the material the ride-on is made of dampens the tire noise .
I found this out 1st hand on my last bike that did the same thing your was doing that when i installed the ride-on to better balance the front tire & protect it from punctures it actually stopped all the moaning/howling when cornering.
So if your tire has a lot of life left in it then it would be worth doing if you find wheel bearing to be ok
scott
Me too! I know it is not the wheel bearing, easy to check. I know it is not the tires as I scrape my Jackpots and that is about as far as the kick stand allows on the left side. I always figured it was the rear hub and belt sound reflected back to me.
I check my tire pressure about every 2nd time out or if the bike has sat for a couple of days.
