What part of the compensator actually fails?
Old 07-10-2015, 09:57 AM
KylePutzier's Avatar
KylePutzier
KylePutzier is offline
Default What part of the compensator actually fails?
I know what a compensators purpose is, but I have never experienced a failure. When a compensator goes bad, what actually happens. Does a part brake (sorry, had to do it) or does it just wear to the point of excessive noise? Does it leave you stranded or can you still ride. Does it affect running at speed or just starting.
Old 07-10-2015, 10:08 AM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
subscribed. interested in the technical side of this
Old 07-10-2015, 12:57 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
It usually does not break or leave ya stranded. It wears over time. Mostly the ramps wear. That causes less/no spring pressure on the lower ramps = slop and noise. The center bore will also wear, causing vibration. The two combined put strain on the crank, primary and starter. You will hear and feel it before it leaves ya along the road, hopefully...
Old 07-10-2015, 02:21 PM
KylePutzier
Old Hippie,
That is the way to reply to a post! I asked 3 questions, you gave 3 succinct and knowledgable answers.
No telling me that proper maintenance is important.
No reminding me that my life is not worth a bad compensator.
No suggesting that I put in an aftermarket part.
Just the info I was seeking. Cool!
Thank you.
Old 07-10-2015, 04:56 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,920 Likes on 8,432 Posts
Or sometimes it does this. Dang it was loud when it was beating against the inside of the primary cover. The spring plates will come off center when compression is released and hit the primary cover. When you accelerate, the springs will be drawn back to center.
Old 07-10-2015, 07:15 PM
propflux01's Avatar
propflux01
propflux01 is offline
Wow! How long was it banging around before you opened it up and saw that?
Old 07-10-2015, 07:21 PM
Bill03E's Avatar
Bill03E
Bill03E is offline
I saw a stack in the dealer, and some that the spring cup was worn, and chunks of it were missing.
Old 07-10-2015, 09:55 PM
escalade6103's Avatar
escalade6103
escalade6103 is offline
Originally Posted by KylePutzier
Old Hippie,
Thank you.
pretty good response. i talked to someone after i replaced mine and he said he has never replaced the whole thing just the spring pack. i did see some wear on the sprocket itself.
Old 07-16-2015, 04:38 PM
EasternSP's Avatar
EasternSP
I was out on a ride with some guys when it let go and started banging. I limped it on home about 9 miles. It didn't break the primary cover but it sure chewed it up a lot on the inside.
Old 07-16-2015, 08:32 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
I go inside my cover every 7k miles to inspect the Baker Attitude adjuster for proper tension and where I see the wear is on the lobes (giant spokes) of the inner hub. It's easy enough to take that area apart, when I start seeing and hearing excessive wear, out she will come.
(If you look just above the wrench behind the first sprocket, you'll see wear to the left of the 'Peak' of the sprocket. Looks like a scrape.)
This was some time ago when I removed this adjuster for the Baker. I don't have tangible data to substantiate my findings but, I found replacing the primary oil every 2k useful in prolonging premature compensator wear. I prefer Rotella T6, but it's not as important which brand as long as it gets changed regularly.
Here's a better view of the wear progressing 10k+ miles later. It still looks real good in there.\
Nickd2689
09-26-2017 04:10 PM
wethead103
2014-2023 Touring Models
10-16-2015 09:18 AM
Bushwacker
08-25-2012 06:23 PM
Sincecrazy
12-26-2010 08:57 AM
HOGBOB
Exhaust System Topics
11
08-29-2007 07:22 PM
Quick Reply: What part of the compensator actually fails?
