rear rotor is hot
Old 08-24-2015, 11:36 PM
scot210's Avatar
scot210
scot210 is offline
Default rear rotor is hot
Trying to figure out why my rear rotor is running so hot after changing the rear stock wheel to a custom rim. Mounted a new tire on the new rim. Changed to brake pads and went for a ride. The rear rotor was very hot. Im wondering if the old rotor is warped or if the new pads are dragging on the old rotor and are trying to seat in. I brought the bike back home and put it up the the lift. The rear wheel turns freely and when I apply the back brake the tire stops. When the brake pedal is released the wheel will turn freely again.
Do you think the callipers are sticking?
How do I check to see if the rotor is warped?
Any suggestions
Thanks in advance
Scot
Old 08-25-2015, 05:33 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
If you used it at all it will be hot for a while. Friction is what makes it work so it has to get hot. If it is not dragging while turning it I would guess it is normal. After use mine is too hot to touch for quite a while.
Old 08-25-2015, 05:38 AM
Assegai's Avatar
Assegai
Assegai is offline
............. seizing up completely notwithstanding, friction would rapidly wear down the pad to allow pad/disc clearance. If you jack the back and manually spin the rear wheel you can confirm correct operation - there will always be some light drag. Discs get extremely hot - wouldn't advise the touch test!
Old 08-25-2015, 06:55 AM
just plain john's Avatar
just plain john
just plain john is offline
Are the spacers on the correct side?
Old 08-25-2015, 07:11 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I would think that if the wheel turns freely like you say,it's just normal.
The best way to check for rotor runout is to use a dial indicator.
If its really bad, you can see it while turning the wheel by hand and the pedal may pulse when applied.
Old 08-25-2015, 08:08 AM
scot210's Avatar
scot210
scot210 is offline
Thanks for the replies. It just seems weird because the front two rotors are no way near as hot. I can touch them and there is a BIG difference in temperature. I am worried that the temp on the rear rotor may cause wheel bearing breakdown or failure.
Old 08-25-2015, 12:03 PM
GTK's Avatar
GTK
GTK is offline
Rear rotor does not get as much cooling air as the front wheel rotors do.
Old 08-25-2015, 05:37 PM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,405 Likes on 1,593 Posts
Also depends on your braking habbits.
Old 08-25-2015, 05:58 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
If it works as you say, that is, no drag brake off, brake on, then no drag brake off again--- ride it. A warped rotor usually will give you 'as you spin' drag - loose- drag and also it can give you a pulsating pedal. If you still think there is a dragging type problem, go ride a bit with no rear brake then check it again. To be safe, spit on your finger and touch it quick. If it is only warm ( from normal pad contact) you should be good to go. If not, further diagnosing is in order. If you wish, I can elaborate further, but I'm thinking you'll be fine.
Old 08-25-2015, 06:15 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Disconnect the pedal. If it is cooler than before, you are dragging the brake without knowing it.
Quick Reply: rear rotor is hot
