Quieter exhaust than stock?
Yamaha Venture slip-ons may be a little quieter. The only difference is the rear mounting bracket is different. I think they're used be someone on Venturerider.org that had made some brackets that was selling them. I remember a while back they were posting the HD mufflers were a little bit louder on the Venture. They're designed for a 98 hp V4 so they shouldn't be more restrictive.
Oddly enough... I just bought a set of CVO mufflers off an 09. These are the baffles without cats, that do a 180 overlap then another 180 turn to exit.
They are actually quieter than the stock mufflers I had
(stock from a 2014 SG which I added since mine came with gutted pipes originally).
Only slightly quieter at idle, but I used to be able to get a little bark when I rolled on. Now the CVO don't really do anything when I roll on it. I want quiet but not silent.
Planning on going the Fullsac route for baffles.
Might be worth a look on ebay.
Try the thunder city baffles, while still using the stock pipes. They quieted down both my bikes quite nicely. I can slide through town almost unnoticed-- just the way I like it.
I have run Fatshotz on two different engine combos. The first set was on a built motor and I tried both open & closed end caps. After putting on closed caps the once powerful motor couldn't make it up a small gradual hill without a push, (needed a re-tune bad), but boy was that quiet. I have open-ended Fatshotz on my stock 103 with cat and I seriously think it is the best sound I've ever heard on any Harley as I travel quite a bit, (don't subscribe to the rah rah rah look at me coming down the road theory).
Touring mufflers from 2008 and earlier will be quieter than 2010 and later. Avoid most 2009s they had cats in mufflers (not all as noted above).
But, as Joe12RK said, 2010 mufflers ( even the 2009 CVO mufflers ) were made to give that Harley sound with a cat in the headpipe, so they will be louder then the earlier versions.
That is why most of the new Harley touring mufflers say they are for 2010 and later.
Also why, if you have say, a 2012 touring bike, and want to put on Supertrapp SE mufflers but have gutted your headpipe you should buy the 2009 mufflers or you won't get the sound levels the mufflers were designed for; the versions for the newer bikes will be louder then intended ( but that may be what some want ).
