Weird steering issue...
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I'm back in AZ for my winter escape, and so I'm now riding the '07 RKC. I've been noticing a strange, and scary, steering issue. If it were a car, I'd say it has serious oversteer.
When I enter a right OR left turn, as at an intersection, I have to hold the opposite grip with some effort, to keep the front end from diving into the turn and jack-knifing the bike. In times past, I remember the bike wanting to self-straighten from any steering input.
Cruising in a straight path remains a hands-off, tracks like on a rail experience, as it always has.
Anyone ever experience this? Not sure if this is related, but when I back up the bike, I hear some of the [front] spokes ping like plucked harp strings. Profile rims.
Check the nut behind the wheel...Sorry, I had to say it.
Check out the rear axel. Make sure that the axel is torqued to spec, and the alignment is on. I recently had an issue with my bike that I was sure was a front wheel bearing. Turned out that the rear axel nut was not torqued properly.
Weird steering issue solved...
Well, I got my "diving into turns" issue corrected. It was as simple as low tire pressure. The front had 13-psi, and the rear had 8-psi. Neither tire looked or felt low.
Since I posted the thread, I found a used Pit Bull on Craig's for $200, and picked up a nice Craftsman pancake compressor at a pawn shop for $45. Once I got the bike up on the lift, I could access the tire valvestems. The only pressure gauge I had here at my winter home, couldn't easily reach the stems to take a measurement until I got the bike up on the lift. The $$$ I saved not taking it to the HDealer likely paid for both tools and the several quick-disconnects, fittings, and other compressor adjuncts I bought. Thanks for all who contributed their ideas; Buelligan666, you nailed it!
