(Torque x RPM) ÷ 5,250 = Horsepower
I always wondered why torque and horsepower cross at 5,250 RPM's so today I googled it.
http://www.motorcyclepowersportsnews...s-talk-torque/
The typical chassis dyno measures how quickly the test bike can accelerate a heavy steel drum – so it’s actually measuring torque (acceleration). Horsepower is then calculated by plugging the values of torque at various rpm into this formula: (Torque x RPM) ÷ 5,250 = Horsepower.
Received 1,505 Likes
Just look at any of the FuelMoto dyno charts to see it and this to help explain http://www.largiader.com/articles/torque.html or any other source like http://www.edmunds.com/car-technolog...on-torque.html. I think most use 5252 as the constant.
It's been that way since I trained as an engineer in the '60s. Some things don't change. 'Tis the case that torque creates power. Amen. 5252 is closer to the mathematical result. Give thanks to James Watt.
The value 5252 is a constant, in other words a product of several numbers multiplied together. Unfortunately the internet is useless in answering basic stuff such as what the full formula is. Now where are my college notes.....
I only ever tested engines on a brake, not a dyno drum, even a V12 R-R Griffin. Impressive numbers, especially when adding water/methanol at full throttle!
Torque is measured at a specific rpm. Motor 1 makes 100ftlbs at 2000 rpm. Engine 2 makes 100ftlbs at 4000 rpm. Plug in those numbers to the formula.
The numbers you listed are PEAK. The 2 engines you list make their peak at different places.
Originally Posted by qtrracer
Oh the software is written that way, but why does my truck make 397 hp and 750 tq and a another engine make 525tq and 560 hp? And 1 hd engine make 110hp and 125tq and another hd make 135hp and 125q?
The formula also says the torque and HP will always be the same at 5252 RPM. That is where those two lines will intersect on any dyno chart.
Depends on WHERE the engine makes its power. Tq TIMES rpm.
