My bike is beeping at me!!! HELP
Hey guys,
Patient is a 2014 ultra limited. Stuck in Japan still so dealer is not an option. Battery died some time ago may I think. I finally got a battery here. Hooked her up and started her. Took a second but she turned over and started right up. Now the bike is beeping!! Three beeps pause for 5 seconds three beeps. They are coming out of the bikes speakers. I turned off the radio and the beeps kept coming. No warning lights, no error messages. It still does it with the switch turned to acc. Took it for a ride to knock the cobwebs off and it beeped the whole time. It seems to start beeping after the Harley splash screen on the boom system. Anyone have any ideas can't find any specifics on this anywhere!!! PLEASE HELP!!!
I suppose it's possible. Guess I'll get ask Doctor Google. Unless someone could tell me how to reconfigure it. So it like "unpaired" from the bike and is now rogue? I mean I paired my phone and could play music through Bluetooth. Beep right along with the music. Almost sounded like the volume Dident change , the beeps that is.
Could it be the Beep in feedback settings?
http://www.harley-davidson.com/en_US...Boom_OM_EN.pdf
If not, back when they first came out and the Boombox would lock up removing the main fuse would help reset it. Don't have a clue what is causing your beeps but worth a try
Harley Tech. Line 1-800-258-2464
This was from another Forum:
http://www.harley-davidsonforums.com...-problems.html
Figured it out!! Thanks to outer banks HD service dept!!! Sadly my radio did I fact go rogue! For some reason or another the ECM forgot about my radio. Now it beeps to tell on me for riding dirty..... Tools me through a bunch of codes and stuff on the radio. Tried to reset it. No dice looks like I have to drag my *** to my closest stealership (while enduring that annoying *** beep and they have to plug my bike into tech me rerecognize me boom system
That's it because I have changed radios before. The upsetting part will be if they want to charge you for it.
New development!
So I Dident get a chance to get it to Harley. Turned it on and it beeped 3 times and stopped! Now the preset number have double numbers. I.e. Big 5 little five. All menu functionality works but it's stuck on mute and here's the kicker.... When u turn the bike off..... The radio stays on! Like for ever..... So pull the battery and hook it back up. It does the same thing. Crap what now?!
Received 70,905 Likes
