Brake fluid 2008 synthetic ??
Received 47,791 Likes
Technically all DOT 4 is "synthetic".... If it says DOT 4, you can mix with DOT 4.
Super DOT 4 (another name for DOT 5.1) is also compatible with DOT 4, just has a higher boiling point.
DOT 5 is silicone based and is not compatible with anything other than DOT 5.
My '03 Heritage is DOT 5 and my '12 Limited is DOT 4.....
I have it written down in my garage and have to double check every time I work on a brake system....
I have " HD's Dot-4 " brake fluid on hand & it says on the label its a Syn brake fluid specifically formulated for HD's & thats about it.
Hope that ans your question.
BTW,dont mix dot-4 and dot-5 brk fluid because in some cases it can cause a bad reaction between them that causes havic in the brake system.
Scott
