Reverse Bleeding Harley Brakes
Hi all,
After minorly sucking some air into my master cylinder while bleeding my front brakes (yeah, I know), I discovered reverse bleeding as a way to not try to suck the bubble through the whole system.
I found a couple of posts that showed ways to do it, and I thought I would share how I did it for anyone who needs it.
I used a bottle of gear lube, empty and really cleaned out, along with a length of 1/4" vinyl tubing, plugged into the bike's calipers, and set it up so that the fluid flowed back up to the master cylinder. Here's a photo of the setup.
I occasionally gently jiggle the brake handle, which pushed some accumulated bubbles out the recirculating holes in the bottom of the master cylinder.
Then I bled the thing back the normal way. The brake is really firm now, very nice.
Here are some links to the other posts I found about this.
http://www.harley-davidsonforums.com...ml#post1142929
http://www.moccsplace.com/images/bra...er/bleeder.htm
Best.
The following 2 users liked this post by sel53:
GriffinDenim13FLHX (08-29-2016),
JesseDyna (08-30-2016)
Spokane2303 (11-30-2018)
ABS braking systems, at their core, are nothing more than a normal hydraulic brake system with a safety system piggybacked to keep the wheels from locking up. If the ABS system were to fail you would still have perfectly normal braking just like a pre ABS vehicle.
skydude426 (08-29-2016)
I agree. After seeing what dot4 will do to paint, I try to keep it contained and controlled as best I can. I use a mighty vac, you can use them in reverse to push the fluid too. I didn't think my clutch was bled out after changing lines for my bar swap. I bled and bled and bled. Then I reverse bled using the mighty vac. I have a long hose so I can stand and watch the master cylinder. Turns out the clutch was bled. The plates were sticking and wouldn't let the bike roll, after up to temp it was like pushing the bike around in neutral.
Lot of good comments. I struggled with most of them before doing it this way.
It is probably hard to tell but that bottle is WAY over from the bike (yes, fear played a hand here), and letting gravity do the trick I didn't have to do much more than check the hose connections every so often (and of course suck the master cylinder often).
i knew I would get an appropriate garage comment from someone ... Thanks for being kind, Stoney
