Worth upgrading to fp3 from older fuelpak?
hello I currently have the older fuelpak on my 07 roadking with true duals,Roland sands open intake, and CFr exhaust and am getting some frequent stalls during stops and it runs well most of time but getting random rough idles etc..any opinions on the new fuelpak? Thanks
The old fuelpak is a piggy back device, the new one flashes the ECM. Quite a bit of difference but those that see the most gain from the new FP3 are those with TBW bikes. The TBW don't seem to respond well to piggyback devices. If the O2 sensors are still hooked up they seem to battle each other. Having had several of the old style. I can say the new ones are much more user friendly and MUCH more adjustable.
There's an app for your phone that allows you to see what's going on in your engine. You can set up nice gauges and such, or start an autotune session. From that standpoint it is pretty much the same as a PV. The difference is that the PV provides the display unit as part of the system, the FP3 uses your smart-phone. Once you get things running like you want, you can remove it entirely and leave it in your toolbox until you need/want to make changes.
You will need to download a tune for your bike via the FP3, ideally before you run it. You will need the app on your smart phone and have the FP3 connected. Then choose your bike and the mods you have, and then download the tune. Good to go and no more piggy back tuner, it's all in the ECU.
