Front brake loss of handle pressure
All,
Was getting ready this morning to go for a ride. Got on and grabbed the front brake like usual, and the handle went to the grip. Wtf...!? Usually it grabs almost immediately. So I check the fluid level and to see if I had any leaks or loose parts. All was fine. Any ideas? No front brake is not cool!
Sorry.
2013 roadglide
Abs brakes
Sorry.
2013 roadglide
Abs brakes
if your weather has just turned cold- this is when you may find that your seals are worn. They are no longer able to seal having stiffened and lost their flex.
for those of us in warm climates, we get away without having to do alot of maint., and we will often experience a failure when we take our warm-weasther bike to the cold.
could be master cylinder- usually this will show itself as the lever becoming soft at a long light in advance of a failure
unless you see fluid leaking somewhere.
mike
mike
Received 5,409 Likes
mike
mike
Yea, I am in Pgh, so not warm by any means.
I was thinking master cylinder. But on a 2013? Wow.
bad seals in the master cylinder would just not seal the edges- imagine a syringe if the rubber does seal on the sides- when the plunger is pushed, the fluid just leaks around the edges behind the plunger.
this is what a master cylinder is and does- it pushes fluid down the lines- a blockage or restriction would make for a hardlever- the master is pushing fluid but it can;t go anywhere....in normal operation that could be the pads against the disks- can only go so far
a soft lever means that fluid is not being pushed against a restriction--- if it isn't leaking out of the system somewhere, then we can assume that no pushing is taking place.
seals are damaged by dirt grit, wrong fluids, water(!) which if turning to ice will tear up seals as it expands- this is why earlier I reference warm weather brake systems.
in PHX it is kinda common for drivers to have brake problems if they go to flagstaff- where the elevation means skiing and below freezing temps from Nov to March.
or LA drivers going to Big Bear on an overnight trip.
our warm weather means that our seals are never put to the test, and that water may accumulate as we are lazy and don;t change out our fluids.
Mike
Mike
Campy Roadie (11-14-2016)
RiverB (11-14-2016)
