Need help with center stand.
I recently picked up a chrome center stand and am getting ready to install it. I'm able to tell that two of the brackets attach to the same bolt holes that mount the lower front crashbar. There are two other tabs perpendicular to these with bolt holes 6 1/8"on center. I don't seem to be able to find anywhere to attach the second set of tabs. I'm including a picture of the center stand that I have. This is going on a 2000 RK Classic. Hope I'm not missing any parts.
Received 6,044 Likes
Having the correct name (display stand) was the key to a successful search. Found a 8 year old post that tells how it is fitted. Remove the voltage regulator and sandwich the stand between it and the frame with the regulator mounting bolts. Then the swivel bolts to the engine guard mounting holes. Should be pretty simple. I need to make some short spacers and that's about it. A job for tomorrow morning after I pick up some longer bolts.
