Road King Code Problems
Looking for some help or advice. I have an 07 road king. 18000 miles, K&N filter, slip on's, cobra Fi2000 tuner. I am getting some codes that started popping up. The codes are P0132, P0151, P1352, P1356. I have taken the tuner off and it didn't help. Changed the fuel filter and check valve and hose so should eliminate the "pin hole" in the fuel line problem. I have new plugs and wires. The codes started showing up before the plugs, wires and fuel line replacement. The bike seems to run fine. No noticeable stubbles. The code will only show up when I get on it or it lugs in too high of gear. any help would be appreciated. Thanks
