03 Road King Starting Issue
Old Jul 5, 2019 | 09:43 PM
cletusrk03's Avatar
cletusrk03
Stage II
Default 03 Road King Starting Issue
I bought an 03 Road King and have put 500 mi on it this spring. It has been starting each time as it should. I took a ride yesterday approx 50 mi, it ran good with no concerns and got home and 3 hrs later went to start and it just cranks. It has spark, checked fuses, unplugged tuner, fuel pump runs when turning on, check valve has fuel, spark plugs good, no check engine light on. Any help will be greatly appreciated. Thanks !
Old Jul 5, 2019 | 10:24 PM
OlAndrew's Avatar
OlAndrew
Check for codes. Likely the crankshaft position sensor.
Old Jul 5, 2019 | 11:51 PM
Terry L Brown Sr's Avatar
Terry L Brown Sr
6th Gear
I had similar problem with my 03, fuel line into tank, quick release not snapped on collar
Old Jul 6, 2019 | 10:02 AM
Max Headflow's Avatar
Max Headflow
You can try holing up on the fuel line connection on the tank while starting to see if it runs. If not try squirting a little in the intake. It should pop off a couple Rs. If it does, you'll need to check fuel pressure. If not crank sensor, tho you typically not get spark. While cranking make sure the battery voltage stays above 9.5 volts.
Old Jul 6, 2019 | 09:39 PM
OlAndrew's Avatar
OlAndrew
Yeah, my bad. If he's got spark, the sensor is probably good. More likely fuel issue then.
Old Jul 7, 2019 | 07:39 PM
cletusrk03's Avatar
cletusrk03
Stage II
UPDATE: Issue was fuel line inside tank. Thanks to all that replied ! Appreciate it ! Thanks again
wideopen4life
Feb 22, 2022 10:32 AM
rjacobs
Aug 18, 2018 05:35 PM
nickgyver
Mar 30, 2014 12:48 AM
preksy
May 20, 2013 03:07 PM
ParkerH
Mar 26, 2012 02:54 PM
