Road king shut off while driving
Old May 19, 2013 | 04:39 PM
preksy's Avatar
preksy
Stage IV
Default Road king shut off while driving
Hi every one. I just by my first Harley road king classic 2001.
Drive it yesterday for a while and on the road just shut off. I try to start but nothing. I wait for 20min and start it and drive for 2 miles and it shut off again. It happen couple of times when I was on my way home. This morrnig I start, and he start normaly.Drive for couple of rounds by the street and it shut off again.
Like when he reach warm temp. it just shut off engine. fuel pump it start every time when I give contact. Also on the shifting gear from high to low it start to fireing, and it shut off only when shifting from high to low. Could be the spark problem? I am in Europe in small country where is only few Harley's.
Old May 20, 2013 | 12:12 AM
im's Avatar
im
Check fuel in tank.
Fill tank to the top and try again.
Reason: fuel line inside tank sometimes gets a hole and at 1/2+ tank of fuel the line is outside of fuel.
Fill all the way to top and see if it goes away.
If it goes away remove the plate on top of tank to access the fuel lines to check.
Battery good?
Did you check the cables for the battery...check at battery and the other end..could also be a loose cable..
Is charging system OK?
Rather minimal information to work with right now?
Old May 20, 2013 | 11:14 AM
JohnCA58's Avatar
JohnCA58
If your not losing lights or instruments, it sounds like your crank sensor has gone bad, next time it shut off, if you had a tachometer, which Road King don't, you could crank it and you would not get a tach reading. replace your CKS and your problem will go away.
have not had a pin hole leak in the fuel line cause a shut down yet. would have to be a big hole.
Old May 20, 2013 | 11:40 AM
user 460022's Avatar
user 460022
Other than the bike shutting off were there any other issues like the turn signals not auto cancelling?
See if this thread helps at all:
https://www.hdforums.com/forum/touri...nsor-fail.html
This might be what John described above as your crank sensor. I have to have my speed sensor replaced on my 2007 UC
Old May 20, 2013 | 02:54 PM
gomiller2's Avatar
gomiller2
I think john 58 is right crank sensor is going out i have a 99 king mine went out bike was doing the same thing as yours bike would shut off like you hit the kill switch let it sit awhile start up go again 5 minutes or so dye again when this happened i checked for spark at plug had none so i new it wasnt fuel had cps changed no issues in the past 4 years very common problem with harley good luck with your scoot.
Old May 20, 2013 | 03:07 PM
mikelikesbikes's Avatar
mikelikesbikes
Best of luck and hope you get it figured out. You must be pretty hot stuff over there in Croatia with a Harley!!!! Beating the babes away!!!
If it turns out to be what was suggested above it is actually called the crank position sensor and costs about $57 from Harley. That might be about $300 for you.
cletusrk03
General Topics/Tech Tips
Jul 7, 2019 07:39 PM
bballkking1
Nov 5, 2016 11:20 PM
rbrown
Aug 7, 2016 03:06 PM
ParkerH
Mar 26, 2012 02:54 PM
marchwoodmc
EVO
Mar 13, 2012 09:24 PM
