best way to fish new TBW cable through bars
take some chain like dog chain that will fit the holes and run them back and forth in each hole some. this will take away any sharp burs and edges. take off the stock black wire coating then tape wires together every 4 inches, then tie a strong nylon string to the end of the wires and tape to a point, then lube with dish soap. this worked good for me even in a cvo set up with heated grips.
Not understanding why you bought another one with the green plug when the CVO TBW comes without it. Do your self a favor and take it back and swap it or cut the green plug out and solder the wire back together. Tape the entire harness then put heat shrink over the entire harness. Once you start feeding it through the bars, only pull enough to take up the slack of what you can push in. Push then pull method.
+1 on the CVO twist grip sensor. Did mine with this last winter...the only way to go & well worth it!
Get yourself one of these...http://www.harley-davidson.com/store/twist-grip-sensor
^^^^THIS^^^^
Saves the aggravation of that damn green connector!!!
I must've been lucky or something, because I thought fishing the wires through the bars was gonna be a complete nightmare from reading posts on here. It literally took about 15 minutes and I had both sides pulled through and even used the factory tbw harness with green plug. I have 10" Yaffe monkey bars.
I used a chain like what's used for your ceiling fan for pulling, and Windex for lube.
