"DIY MODS" and TRICKS to SAVE $$$$$$
Old 09-25-2014, 07:50 AM
VA_Larry's Avatar
VA_Larry
VA_Larry is offline
Default Saddlebag Quick Disconnect Replacement
Originally Posted by 04ctd
from another thread, put them in here for reference:
I ran up to Lowes this weekend,
it's hard to find the parts in the drawers, so i took pics:
I added an o-ring on the bolt between the saddlebag and the speed nut. When I disconnect the bag the bolts stay in place.
  #1632
Old 09-28-2014, 07:46 PM
04ctd's Avatar
04ctd
04ctd is offline
I park at the END parking spot at work, so i got a piece of aluminum diamond deck from somewhere (I think Lowes sells them)
i put it in the striped zone...so no one will have to drive/park over it.
and I ground all the edges off, and the corners down, drilled four holes in it, and counter sunk them, and made me a permanent parking pad for work
i was amazed how much the screws bit in to the asphalt
  #1633
Old 09-30-2014, 08:53 AM
inkdemon's Avatar
inkdemon
inkdemon is offline
That's all nice. But unless you own the lot, don't be surprised if it dissapears. As whoever cleans and manages the lot may not want a piece of aluminum screwed down to the spot. Or if it comes up for recoating.
  #1634
Old 10-11-2014, 10:42 PM
Toby_2014's Avatar
Toby_2014
Toby_2014 is offline
There is a great youtube video on hiding the antenna on a RG or SG without spending the 300 on the kit HD sells.
  #1635
Old 10-12-2014, 08:54 AM
Spazz's Avatar
Spazz
Spazz is offline
When wiring up your new bars for internal wiring...
1. Use weed wacker line for a fish thru the bars..
2. Pick up a bottle of wire lube... I use it for running wires in conduit... stuff works... like KY for wiring...
Lar-Dog (05-09-2020)
  #1636
Old 10-12-2014, 03:22 PM
GibsonSG05's Avatar
GibsonSG05
GibsonSG05 is offline
Little different approach to the "garage door opener" mod for people with road kings. Instead of using the hi-beams I relayed it off of the 12v power outlet on my bike wired to the left aux switch.
  #1637
Old 10-13-2014, 07:32 AM
collin's Avatar
collin
collin is offline
http://youtu.be/RxY6NU2xBR0?list=UUS...VwBezsf3wdFB1A
I did the same but I replaced the left toggle switch with a waterproof momentary switch from fleabay and used a 12 volt remote.
  #1638
Old 10-20-2014, 02:21 PM
KaozDesigns's Avatar
KaozDesigns
KaozDesigns is offline
Default Siren Relay Setup
Kruzin,
Can you email me the jpg image for this schematic? All I can see is the link but not the image.
Thanks
Kaoz
  #1639
Old 10-29-2014, 06:51 PM
flips's Avatar
flips
flips is offline
Default My take on garage door remote
I soldered two wires on either side of the button on the remotes circuit board, ran them to a momentary switch. Mounted the remote inside the fairing with tie wraps and installed switch on fairing. No need for a power source other then the 9v battery in the opener. Works like a charm.
Back of switch inside fairing
  #1640
Old 10-30-2014, 09:15 AM
jamess71's Avatar
jamess71
jamess71 is offline
I like it, and seeing that remote has a 9v battery you should only have to change it every couple of years or so.
UltraRider260 (10-09-2017)
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
