pinstripping removal
01-15-2008, 04:49 PM
removing pinstripping not factory .the stuff thats painted on at rallies
flames ,names ,etc any ideas?
not a whole bunch just a couple things i changed my mind about
after the fact
01-15-2008, 04:52 PM
RE: pinstripping removal
good luck!![:-]
01-15-2008, 04:53 PM
guess this may require a paint job?
01-15-2008, 04:55 PM
ya think??? if the stripe paint is removed,, wouldnt the factory paint come off as well?
really, really fine sandpaper, a block, and water. then use some rubbing compound to take out the fine scratches from the sandpaper.
Piece of cake - Easy-Off oven cleaner will pull it off, no sweat!! Jest rub it on, let it sit, rub off. Won't hurt the OEM paint.
01-15-2008, 05:01 PM
ok .do ya try this in an inconpicuos spot first? just in case
thanks
01-15-2008, 05:21 PM
What happened? Change OL's?
01-15-2008, 05:27 PM
lets say i'm glad it wasn't a tattoo
no it's nothing like that. i'm changing to some hard bags on my classic
and wanted to do something different since i will have quite a bit of room to work with
on the hard bags
01-15-2008, 05:30 PM
Quote:
ORIGINAL: pled55
after the fact
heheh my first thought was the same as duracell's .. (c:
I'd try this before using other methods...
http://www.ehow.com/how_17653_remove...nstriping.html
good luck in what ever you decide...
99%r
