If you have the instrument pod that is shaped like a "D" with the flat side facing you , there's two bolts looking up at you that get removed and you'll find a row of breakers under there up front.
Thanx anyways glide! I was looking for a fuse panel and this model has inline glass fuses behind the headlight!! Problem solved... I just popped in a 5 amp glass fuse,,, and the Eagles "Take it Easy" started blaring!! sweet!
